O.K. here"s the situation. I have an IH 400 with a single set of hydraulic couplers. The hydraulics are very slow. I"d like to mount a front end loader but need two sets of couplers. I"d also like to install another hydraulic pump to increase flow capacity & speed up the hydraulics. I"d like to mount the hydraulic pump at the front (run a pto shaft to the front of engine /attach it to the pump), AND attach the system to the hydraulic reservoir. The question I have is, will the installation of the second pump cause any damage to the pump that is installed in the tractor? Has anyone done this before? If so, any cautions or advice would be appreciated. Thanks in advance. Sluggo
