Anonymous-0
the 515 i'm working on that we thought was just a head gasket seems to have a bad o ring on the bottom of a sleeve. water getting into oil just setting there. after reading the service manual that i have, i'm not srue i understand how the motor is hooked to the trans. according to the book, once you take the bolts out around the bellhousing, the motor and trans will seperate leaving the torque converter in the trans. if this is the case, how is the torque convertor connectec to the crankshaft? i'm confuses. also, i'm looking for the lower pivot pin, where is a good place to go to look for one.
thanks
Gary
thanks
Gary
