What all did MW make?
What all did M&W make for the farmall tractors?
What i can think of
9 speed
govenor
throttle handle
hand clutch
PTO lever
What else am i missing?
I will add a few: stroker crankshaft kit for
the M-450 tractors
numerous add power over bore and high
compresion piston kits for all brands of
tractors
add on turbo chargers for all brands of tractors
oversize oil pans
air pre cleaners
they also made turbo charger kits, sleeve and piston sets over board pistons SWD9 and many more
Gear reduction starter drives so 6v would turn it over with all the added compression.
M and W made a different radiator grille for the M farmall that had smaller holes and also was raised up on the front - to keep hay etc. out of the radiator....
Think it was called a "Super Snoot"
The linkage kit made it easier to push in the clutch pedal.
With that and a block of wood fastened to the clutch pedal, lots of boys too small to really drive a big tractor like that drove them anyhow.
(quoted from post at 06:23:07 12/19/09) M and W made a different radiator grille for the M farmall that had smaller holes and also was raised up on the front - to keep hay etc. out of the radiator....
I thought the super snoot was used in corn picker operations to get fresh air in bc the nose was blocked by the mounted picker. I may be wrong.
(quoted from post at 21:58:06 12/19/09)
The screen in the grille would get plugged with trash and cause overheating. the Super Snoot screen was above the grille, it would still plug once in a while but was a lot easier to clean off.
