Diesel sediment bowl gasket
plow hand
Does anyone know the part# for the rubber gasket on the diesel sediment bowl on a WD-9. Who handles them? Thanks
Case-IH still sells them part number 251352R1. Messick's has them on their website nice people to work with. The link is for a super MD water trap but the same part is used for the 9 series.
Andrew
poke here
sorry the link does not work fully to where it is supposed to go... just type the part number into there site and it will come up. cost 11 dollars and some odd cents.
Andrew
With a engine serial # below 5387 the gasket # is 60876D. 5387 and higher is # 260708R2. In case the water trap was changed in the past, the one that uses gasket 260708R2 has a drain valve with rod ears on top to open and close. Also has a curved tube going down into bowl. Early types had straight tubes. external_link shows both gaskets with a price. Dealers could get the latest gasket, but not sure about now.
