I have finally got my 560 into the shop and the pump tore off to rebuild it and have run into a problem. I cannot get the steel distributor end to come out of the aluminum housing. I have taken out the two small bolts that go into the housing and the larger 12 pointed head bolt that goes up thru the bottom but cannot get it to withdraw the housing. It will turn very slightly but not come out.
Before I go forcing things or removing something I should leave alone I thought it better to ask and see what else may need to come out to get it to seperate. Besides taking the cap with three screws off the top and removing the supply pump endcap these are the only other bolts I have taken out.
Thanks in advance for any help.
