F-11 loader and Farmall M tractor
I have a Farmall M with live hydraulics and I have intentions of mounting a F-11 loader including the PTO pump. Can I use the F-11 hydraulic tank for the live hydraulic reservior also? Can I plumb the live hydraulic pump into the F-11 system so the loader will operate with the clutch and PTO disengaged thus the PTO is not spinning? The M originally had an older Dual loader with an auxillary reservior tank attached to the Dual frame and to the live hydr pump. I have removed that machine. Thanks
(quoted from post at 20:01:51 01/27/10) I have a Farmall M with live hydraulics and I have intentions of mounting a F-11 loader including the PTO pump. Can I use the F-11 hydraulic tank for the live hydraulic reservior also? Can I plumb the live hydraulic pump into the F-11 system so the loader will operate with the clutch and PTO disengaged thus the PTO is not spinning? The M originally had an older Dual loader with an auxillary reservior tank attached to the Dual frame and to the live hydr pump. I have removed that machine. Thanks
If you are going to run the loader with live pump on the tractor, don't even use the PTO pump, remove it. You will probably have to use the loader hydraulic tank as your belly pump reservoir will not hold enough oil to operate the loader.
(quoted from post at 19:04:28 01/29/10) Kirk:
Will that live power pump put out enough gallon per min to be as good as the PTO pump?
No, the live pump puts out around 12 GPM, while the PTO pump, depending on size, will put out 11-23 GPM
