113 cam help
FLOPGUNS
Hello, i am going to rebuild the motor in my super-a. i can get all the rebuild parts but the cam it is not available anymore. surely all the rebuilds going on someone needs a cam once an awhile what are they doing for a cam
I have never seen a worn cam in all those engines i have rebuilt so i dont seeany reason to change yours the lobes still arent worn are they? Just make sure when the single dot is on the tooth of the crank and the 2 dots areon the mag gears two dots. When they are lined up you are on tdc then install the mag,dixt to #1 fire.
And do not for get to get new lifters too or the new or reground cam will not last long , Don't know where your at but i have had severl cams done by R&R macine in Akron Ohio and also for the pulling engines HAPCO in Terre Haute Indy.
