Weight of Super A
Billy C.
Anyone know the approx. weight of a 1953 Super A with wheel weights on back and cultivators on it? Also what should the oil pressure be? Thanks, Billy
That tractor will weight about 3000 lbs as it sits. As far as oil pressure goes, it could be as high as 60-70 psi but anything over 10 psi at idle hot is just fine. If you have low oil pressure post back as there may be an easy. Sam
