INT, UTILITY I.D.
Anonymous-0
Hi all, just found a tractor that has a 6 cyl. diesel stamped INT. with a loader and it's in pieces. the rear tires are 13.9 x 38 has 1 wetline . Could this be a 350 or 400 series ?
Thanks --- Larry
It would have to be a 460, '60 series' or newer, International did not use a 6 cylinder in any older 'modern' utility model.
Just a note though they did use a 6 cylinder way back in the WK40 but thats certainly what you dont have.
Andrew
Well if its a 460 Utility, your looking at about 45-50 horse. They were produced from 58 to 63. Look at the link and that will tell you more about it
also i would type IH 460 Utility into google images and see if thats what it looks like.
a picture is worth a 1000 words here...
Andrew
460
it would have to be a farmall as the utility has 28" rear rubber. but whats with the INT.stamp? maybe you meant 28" instead of 38" tires?then everything would make sense.if you posted the serial # thats the easiest way to tell.
