TD-25 Crawer
510plows
New User
I know this is a little off the normal tractor subject but I found a farm place that has lots and lots of old equipment that needs to be cleaned up. There is a TD-25 dozer sitting in the weeds and I'm wondering how heavy a dozer like this would be. It sure looks neat with the 6 cylinder gas start diesel engine with dual exhaust pipes. It also has a cable drum on the back. Thanks much Charlie
(quoted from post at 11:07:41 03/24/10) I know this is a little off the normal tractor subject but I found a farm place that has lots and lots of old equipment that needs to be cleaned up. There is a TD-25 dozer sitting in the weeds and I'm wondering how heavy a dozer like this would be. It sure looks neat with the 6 cylinder gas start diesel engine with dual exhaust pipes. It also has a cable drum on the back. Thanks much Charlie
That would make it a TD24 then, with the D-1091. Base weight is about 39 thousand, roughly another 6 to 9 for a blade, about 3 for cable stuff.
M DIESEL is correct the TD24 is starting on gas
and transfer on diesel and the TD25 is direct start diesel and has a 817 motor in.
