steering box on 300U
hey guy's my steering box is leaking gear oil on both side on my 300u, can i remove the 2 pitman arms and pick out the seals from the outside and just tap in new ones?
also who might carry those seals? thanks.
Mike, New seals probably won,t last long unless you replace bearings or bushings in that box. Most people just pump it full of grease through the drain plug hole. John Deere corn head grease is the stuff to use. Good Luck PUTTER
