Nebraska Cowman
French built Utility Diesel What to do next. It's getting antifreeze in the oil. Need information and ideas. The block looks the same on the outside as the US made gas Farmall C size engine. I wonder if with enough $ I could have one machined? The head is toast too but maybe I could weld that.
If you have it apart, it should be clear where the fault lies. Are you suspecting crack failure of head and block both? If sleeves are needed LA Sleeve can make them or might have them in stock!
Jim
(quoted from post at 15:10:45 04/09/10) French built Utility Diesel What to do next. It's getting antifreeze in the oil. Need information and ideas. The block looks the same on the outside as the US made gas Farmall C size engine. I wonder if with enough $ I could have one machined? The head is toast too but maybe I could weld that.
There is a French IH tractor site at:
http://www.lestracteursrouges.com/fichier_tracteurs/les_tracteurs_ih_au_catalogue_francais.htm
If you have Google Toolbar installed it will translate site to English by pushing Translate buttom.
Good Luck
JimB
Yeah, I found that site. But they don't list many parts for the FU235D
I think the head gasket for the FC may be the same.
