IH 424 Manifold
Don't know for sure on the 424. You'll have to look but there should be a u-shaped pipe bolted to the exhaust manifold. If so then a upright pipe can be made to work if you can't find the right part. But, you have to cut a hole in the hood. The only time I don't like an underneath exhaust is when I'm adjusting something behind the tractor that takes more than a couple of minutes -- exhaust smoke. You might look at the parts search on www.caseih.com, provided they include the 424/444.
Diesel? If so, I think the answer is YES, after looking in my parts book..
You can go to the link below and look at the parts book to check out what was available.
Parts
The 424 I used to have had a vertical exhaust. Someone changed it over before I got it. It had a jury rigged flange that did not work very well and came loose. I found that the manifold was threaded just like many of the other Farmalls. I just borrowed a pipe tap (1 1/2 NPS I think) and chased the threads and screwed in a short length of pipe.
If diesel with the BD-154, yes. Some 3414s and B-414s use the same engine with the vertical exhaust option. B-275 with the BD-144 may also fit.
I'm assuming you mean the exhaust and not the intake? The gas engines with downdraft in IHs mostly on the BC-144 engines with British-Zenith carbs. Not used on 424s as I recall. Just B-275s, B-414s. 3414s, maybe the 434, 354, 3444, etc.
