Loctite 620
Ernest
Well i still have not done anything with my Super M and loose liner. I talked to my uncle who works for a machine shop and they use loctite 620. Well just minutes ago I was looking up Loctite 620 and lo and behold John Deere uses it! Probably just like caseIH does.
Untitled URL Link
Snug but the piston lifts it out! It needs pressed in with light pressure and will lift out easily also. It does not wobble in the bore.
The head will hold it down.... Use the 620 sparingly... Very sparingly... If you ever hope to remove that sleeve again.
