IronAddict
Hello all
I am rebuilding the second of my 3 W-4's. The first one went so smoothly. Only needed the basic overhaul kit (sleeves and pistons) I figured the second would be similar. ..not so lucky! After checking out the crank I decided that it should be ground so I had that done and bought the new bearings. While that was at the machine shop I was preparing to install the sleeves and noticed a crack in #4 cylinder. So I tore down the motor of my 3rd W-4 and found that block is ok. With all this time and money invested I'm thinking that I really should replace the cam and lifters because they are a bit rough looking! Does anyone here know where I can get them. I have been searching the net with no luck. May be a "dealer item"?
Thanks all!
Thanks all!
