Chris Klein
I just dragged home a 55 IH 300 utility in non running condition. The problem I am having right now is that it will not roll unless the clutch is pushed down. All it will do is the rear wheels will turn in opposite directions as if it was in gear. Also the engine will not turn unless the clutch is pushed down. All I have been told is that the pnly two problems when it was parked is the T/A had not worked in quite some time and that the hydraulic pump was leaking pretty bad. Could the T/A be causing this ? I am not familiar with the T/A tractors and appreciate any advice
