Dan Swanson
I need to fix and/or replace the lateral control arms system on this tractor. The casting with the 1" or so holes on both sides of the transmission where the lateral limiter control arm attaches (Rear Support?), are broken so a control arm arm can't be attached. There are no lateral limiter back to the 3 pt arms either. Has any one come up with a way to remedy this problem with a welder, chains, etc. Or do I have to try and find new or used parts? Has anyone put on movable blocks like the JD 4020 series have? I thought about this but I think I will bust the crank arms. All I need is something to allow me to attach an 8' mower and not have all the side movement. Thanks Dan
