help for sickle bar mowers
hoopy
New User
i have a international cub low boy can i mount a sickle bar mower on it?
i also have regular cub with one point hitch on it do i have to take hitch of to mount a sickle bar on it? thanks for any help.
hoopys57
Cub-- Model 22 Mower
Cub LoBoy-- Model 22L (same as Model 22 except shorter mount brackets)
Numbered Series Loboy-- Model 222 (has counter rotating balance gear)
They are all mid belly mount.
K-Mo
The special LoBoy model is tough to find, and expensive when you find it.
Regular Cub-22 mowers are very common and you should be able to get one for less than $200.
A regular Cub-22 will mount on the tractor without removing the fast hitch. Just use longer bolts, and tie the fast hitch all the way up so it doesn't rub on the belt.
I have an excellent restored sickle mower currently in the Photo Ads. It came off my International Loboy that I just purchased about a month ago. If interested I can send a set of pictures if you give me your email address.
Don't you love it when supply meets demand.
I just got an email from a guy who needs a mounting plate for an Electrall Farm Duty Baler motor. I have one and will have an exact copy fabricated for my friend.
Both of these transactions were made possible by the info that flows through this forum.
