IH HYd fittings
henryv11
Both my M and W9 have the older syle IH hyd connections. The kind that both hoses from the remote end meet in a holder and than the tractor end has the other connection where you inset the holder into it and than connect them by using a screwdriver to force them togeter. The tractror end has a spring loaded clip affair. There were common in the old days. Does anyone make these or can you still get the oil rings ect to repair them. I hope I have made myself clear on the type Iam speaking of. Thank YOu
I know what you're talking about.I have never seen a complete set.They are probally long ago obsolete.You would be better off to convert to 'Pioneer" or similar
I rebuilt a pair several years ago. Some of the parts came from CaseIH and some from The Depot. Don't know the URL of The Depot but it should be in the archives.
Compile a list of the parts you need and start emailing it around to long established dealers.
The couplings come up on eBay once in a while. Even the implement side.
Aero-quip if I remember correctly. Needed a special nut to compress the spring and screw end out to repair. I can't remember if you replaced just the o-rings or the little tube had a seal made right on it. That is what was in use when I started on the IH tractors. Dealer should be able to steer you in right direction if parts are available anymore.
Thank you Pete 23 I could not remember the name. When they are working right you can not beat them for hooking and unhooking under load.
