444 hydraulic fill
Anonymous-0
cant find a dipstick and I think there is a fill plug under the seat, front side between two vent valves. any type fluid ok?? any help filling and level is appreciated,
Steve F
Hi Steve,
Fill plug is behind the seat on top of hydraulic reservoir casting. When you look in the filler plug hole, you will see sort of a shelf down there. Full level is covering the shelf. Do not over fill as there has to be room for expansion and if you have a loader for return oil.
Use IH Hytran or equivalent hydraulic oil.
JimB
