A and Super A steering box
Billy C.
Are these two the same? About to order a manual so I can rebuild steering this winter to get about 3/4 turn of slack out of it. I DO NOT want I&T manual--have found them sorely lacking for the green tractors and probably the same for the red ones.
You dont need a manual but you do need to look and then determine where the play is coming from. Start with the tie rods then go to the arm coming out of the steering box. Are the tierods loose there and then does the arm move up and down . There is some bushings inside the sector a key and some bearings. They all need to be in shape as a little play here and there all adds up.
