Super A Hydraulic pump
I was wondering can I run a Super A temporaily without the Hydraulic Pump being installed? I am in the process of redoing the pump seals, so it is off - Looking to change the oil, so I would run this for a few minutes to get the oil warmed up.
Yes by all means you can run the engine but you better cover the hole as oil will flow out the place where the pump was.
Why, just let it drain for a little bit longer. Its all pretty much in the pan now anyways, wont take that much longer to drain. BUT if it were me, I wouldnt change it until I got the pump back on.
