FARMALL WEIGHTS
C CUSTER
New User
I need some info on front side weights for farmall tractors. The parts numbers are 271389R3, 271390R3 and 371202R2. The 202s are front slab weights but bolt into the sideweights. I am wondering what model tractors these would fit. Any info helpful.
the only setup that has front weights that bolt to the side weights that i'm aware of are on a 340/240.
p s, i checked the ih parts lookup and the 240/340 use 371389R1 and 371390R1 as the side weights. the slab weight # is the same as you had.
