How much can my Farmall H handle?
Anonymous-0
I am looking to get some small tillage equipment for my Farmall H to use in some larger gardens. How wide of a disc or field cultivator/digger can it pull pretty well?
I think you will be pleasantly surprised.
I am far from an expert on this question. But I can share my experience. For the past 2 years I have been using a worn out distillate 44H (burns almost as much oil as gas) to plow and disk my 2 acre garden. Equipped with a Saginaw 3 pt, and she has handled everything I have thrown at her with out flinching. I have used a 6 foot tandem (about as deep as it will go), a 6 foot brush hog, and a 2-14 plow. I got the plow stuck year before last and broke a wheel center out. The old H has plenty of power.
HTH
KenB
Ken B is on target. The H will do all he describes.
Put a over running clutch on any Bush hog or belly mower used for safety in stopping the tractor,
Jim
Thanks Guys, is a 12 foot field cultivator out of the question? Not looking to go real deep, but there is one locally that looks to be in good shape for a good price.
Yes it is too big as is. It might go to 3 or 4 inches and still pull OK but I would consider a 6 foot (maybe 8 shanks) to be max at about 6 to 7" depth in open non sod ground.
Could it be cut down reasonably, to reduce the size?
Jim
There ya go! Cut that big cultivator in half and sell the other half to someone else who has a similar sized tractor.
A field cultivator is designed to be pulled 3 to 4 inches max. If you want to go deeper buy a chisel plow. A 12 foot cultivator is to much for an H maybe to much even for an M in some soils.
i just plowed 10 acres with 3-16 inch plows with my h. mine pulls them even when they're all the way down. iv gotta go in 1 or 2nd gear but them tractors git the job done.
I pulled a 12 foot spring tooth drag in 2nd. It worked it pretty good in 3rd. I think mostly because the ground was so soft from moldboard plowing that it had to over come rolling resistance. I would suggest 8 feet. It has pulled a 7 foot horse drawn disk nicely. With a moldboard plow, fewer bottoms and a higher gear will give you a smoother field.
Could you describe how you've weighted your H to enable it to pull a 3-16 plow "all the way down" as you claim? It's been my experience that even a M has to be weighted with liquid in it's tires and/or several sets of wheel weights to capably pull 3-16's in average soils....and the average M outweighs an H by 1000 lbs. or more...and has around 10 more drawbar horsepower. I own both an H and an M and I find the H happy with 2-14's (IH Little Genius No. 8 with plow chief bottoms). The M can pull the 3 bottom plow.
