glennster
still fooling with this 254 international mitsu 3 cyl diesel. got it running finally this weekend pull starting it. clutch is stuck. been sitting two years outside. there is no access hole for the clutch, so without splitting it, i cant get in there. tractor has 3 speed trans with a low med and high range. pulled it with the clutch pedal down quite a bit, still wouldnt free up. gonna try maybe 2nd gear in high range with some generous stomping on the brakes. i do have a dirt scoop i can put on the three point and see if i can drag that. any other thoughts?? tractor does have a loader on it too.
