Ed Dibling
New User
I need some help with the hyd. on my 560. I have power to the front end loader for about 1 min.( enough power to lift the front of the tractor off the ground) then I have very limited power( barley enough to lift a 500lb round bale). I have hooked up a pressure gauge right off the side of the pump housing and have about 1400psi. I have this pressure only when the valves are moved but have the same psi when i have power and when i have limited power.
I have isolated all cylinder (one at a time) to make sure there is no blowing through. Same results when this happens.
Any ideas??
Any ideas??
