Farmall 140 step ?
OB OBrien
I'm disabled because of bad legs and knees so have a real problem getting on and off my Farmall 140. No problem when the cultivator is installed. I can then use it as a lift to get up into the seat. But I have a real problem when the planter is under to tractor. There's nothing to use to step up with.
So I'm wondering if someone has ever heard of some kind of a step mounted on the side, or some way to do it. Thanks OB.
I've bought several items from these people with no problem. Check out bootom right pic:
http://www.external_link/new/sp/sp_001.htm
Here is a pic of the step my uncle built for Grandpa's 100. It is very sturdy and you can easily put both feet on it at the same time.
Tell me about your steps Gene. How bout some pictures. Question will they support me? I'm 6 ft 9 and weigh in at a measly 350 pounds.
OB
The bolt pattern on the final drive at the front is the same as the A,B,100 and 130 correct the ones i sell do fit the As and Bs. Send an e-mail as i dont post pics here.
