Torque for jamb nut regular nut on H
Hi,
I am replacing the bolts, nuts, and jamb nuts for the wheel clamps and need to know the torque value for the both types of nuts. Should the jamb nuts have a lower torque value? They are grade 2, 5/8 jamb nuts and 5/8 nuts. Thanks for your answers in advance.
never heard of a torq spec fot that.just use standard torq specs.OR just make em TIGHT with a long wrench(not a short ratchet)...better still,use a rattlegun.They will be just fine!
There are "standard" torque spec charts on the internet. Do a search and you should come up with a lot of good info. This is what I used when rebuilding the rearend of my H. I noticed a lot of the items did not have a torque spec and I tend to get carried away and over tighten things.
