Chris Bordeleau
New User
I am getting my 240 in order and changed the transmission
fluid... crappy brown fluid came out... I put hytran fluid as the
owners manual said in up to the fill hole and am now seeing a
drip where the drive shaft comes out of the transmission...
So I am figuring that gear oil (either 90w or 140w) might be in
order... It is a bit of a grinder to get into gear if you don't start in
gear with the clutch depressed (then it shifts just fine most of
the time) so I am figuring the heavier oil might help here to...
I just wanted to run this pass some people who probably forgot
more about tractors then I know
thanks
thanks
