450 hyd pump plug
756puller
i just got the motor running on my 450 today went to bleed the hyd pump by loosening the screw on top of the pump, just my luck the plug flew out and i dont seem to be able to find it, is this plug just a regular old pipe plug?
There is a spring and ball (about the size of a BeeBee) under the plug. I never had to replace the plug so I don't know the thread. See if a 1/8" NPT grease fitting will fit. If it does, then you will know the size.
