Priming 2444 Hydraulics
fyr808
My son and I just completely flushed all hydraulic fluid out of the 2444 due to bad water contamination. We pulled the bottom drain on the rear end, removed and cleaned lift housing, rinsed and blew out all of the lines, steering rams, and loader rams. We started it today and it won"t prime. No rear lift, steering, or loader movement at all. Any help would be appreciated.
Hi did you clean the suction filter? Drive the tractor into a ditch where the front wheels are much lower than the rear. If that does not work, remove the hydraulic filler plug and with air gun and a clean cloth to seal around the air gun stick it in the hydraulic filler hole and slightly pressurize the reservoir.
JimB
