I was hooking up my "41 H to my haywagon in preparation for our big neighborhood 4th of July party when the clutch couldn"t be engaged or disengaged, so I started to tear into the clutch to find out what the problem is (the threads on the clutch pedal rod is fully extended, so I figure its the clutch)
According to the IH service manual, it says to remove three of the six clutch plate-to-flywheel bolts, move them inward to the three tapped holes and install them with washers under the heads. So as shown in the picture, I moved the three bolts from A to B (at the bottom of the photo), then removed the last three bolts on the outer diameter.
The clutch plate and clutch disc should drop off the flywheel, but they"re solidly on, which makes me think all I did was screw the first three bolts back down to the flywheel.
What am i doing wrong?
Art
Art
