Delco Remy Distributer Problem...DC CASE
Anonymous-0
I just posted a question regarding the Delco Remy distributer on our '51 DC CASE. Distributer probably started out life on an M or H Farmall. Any repair suggestions you may have are appreciated.
Thank you,
Glenn F.
I agree with N Cowman
The fact that it (on the Farmall) sticks up in the air. can adn does present moisture related issues.
Make sure there is no play in the shaft at the breaker cam. (side to side) it needs to be less than .001" slop there to assure good timing and good point gap. Use Delco parts, not IH parts, IH will, in some cases, fit but not work Jim
