I give up, cant get multiple valve body off 1066 hydro
Tbone8
Ok, I need to replace the JIC fitting on the back of the multiple valve body where the oil cooler return line goes. I took all 7 bolts out, it will not budge. I don't see any dowel pins in the parts listing. I am at my wits end. I am hoping for a miracle from someone.
Tom
No good ideas here from me. I thought there might be a jumper tube from below holding it up but don't see one in the book.
There are 2 dowel pins if you look at the parts list they are in with the valve body part.
This was on the multiple valve body and not the multiple control valve correct?
Yes, the multi valve, not the MCV, I sure don't see those dowels pins in the parts listing. I am gonna try a clawed nail puller to try to wedge it loose. Its not the easiest space to work in, kinda tight.
