puller engine?
reddie
hey guys looking to build a 3500rpm super stock tractor with 410cid max. rule. just wondering if a 360 out of a 766 or a dt360 out of truck or a 361cid out of a 1206. or a 407 out of a 1456. just wondering which one would be best to build some decent cheap hp. and if any of them will fit into a 460 rearend.. thanks for any info
An opinion only, A 460 is an H based final drive. If you cranked the gears as you intend I believe it would be a grenade. 460s had to be recalled to fix weak bearing issues when new. THe big chassis is tougher.
A mid 60s mid size massy rear end is tougher. Jim
