Super C Fast Hitch to 3 point conversion
Looking for a set of drawings or prints for the Farmall Super C fast hitch to 3 point conversion I see for sale from time to time. I would like to make one but need drawings and dimensions to build it.
Here is a photo of a commercially made unit. I have lost the mfgrs name. I think you can reuse some of the similar existing parts from your tractor. Maybe this will help you.
good luck.
OB
Drawing looks like it is from A, SA, 100, 130. The top -3rd link on a C, SC, 200, 230 usually bolts onto the rear of the transmission housing, as in where you would mount the belt pully drive, wouldn't it ?
I would like to do the same on my 200 2-pt FH
I think he is looking for the arch that plugs into the Fast Hitch sockets, not something to replace the Fast Hitch.
Dimensions are going to be tough to come by unless you can find one and measure it yourself. It's a commercial product, and the manufacturer is certainly not going to give you their engineering drawings... They're in business to make money.
Or, you can roll your own. All you need is a 3pt implement to measure up, and use as a welding jig for the arch frame. Insert two blank fast hitch points into the sockets on the Super C, back up to the arch, and weld them together.
