Cub with knock is home now
Tom in Mo.
It runs very well and strong except for the knock. I dropped the oil pan and looked around but all looked good. Put fresh oil in and drove it around mowing with the flail mower. Still runs good and still knocks. I will pull the engine this winter and look inside.
Maybe it's as simple as adjusting the valves. I had a Minnie Moe where one tappet was out nearly .100 of an inch slop. It didn't run very well though, unlike your Cub.
is the sound truly a knock, or is it closer to a loud tick? If the sound is closer to a tick, check the valve lash.
Also, did you check the connecting rods while you had the pan off? quickest way to check the connecting rods with the pan off is to turn the crank back and forth just a bit with your hand on each rod at the cap. if you feel slop when you "rock" the crank, you have a bad rod bearing. BTW, there is a difference between "slop" and "clearance". You could also check the mains, but that is best done by dropping the caps. You'll need a torque wrench to put them back on.
If those are all good, you might have a bad wrist pin in one of the pistons.
Sure that a sound from the flywheel/ clutch area isn't getting telegraphed up front? Loose flywheel bolts/ worn clutch splines can make noise. Does the sound vary with RPM or engaging/ disengaging the clutch? How about a tooth out of the timing gears?
I haven't experienced it on my Cub, but had a significant knock from the front of my SMTA. Turned out to be some chipped teeth on the cam gear. Could be a possibility...
Ben
The knock is steady with the RPM. Clutch in or out doesn't make a difference. One thing interesting is it does not knock for the first minute or so after starting, then it knocks until it is shut off and cooled. When I get into it this fall, I will start looking at things on my way into the engine. It absolutely does not smoke a bit, super clear exhaust under any load. This will be a fun project.
While it's still running, get an engine stethescope and try to locate the source of the noise. Might save you some time,work,and money.
check fan bushings. mine were worn to the point that the fan was catching the shroud and the internal oil slinger was cherping. good luck, d.coleman
Oil pressure is lower than I would like it to be according to the gauge on the filter housing.
A few years ago (10) a man I knew asked me to stop by his house to check out his cub that had a knock. When he started it up it had 30 lbs oil pressure and made no noise until he gave it a little gas. He had spun a rod bearing that would slide around and the knock would go away. When the bearing moved around the piston would slap against the head. Had to have the crank reground and a reconditioned rod, new bearings, etc. Runs great now. Good luck.
