I have a Farmall 300 that I have used yearly for pulling the drag in the small acreage I use for corn and vegetables I grow. I also use it for raking hay as well. It's in a very as is state. Tractor will start right up but always sputters. Not sure why. I have over the past couple years changed nearly everything to do with the problem. Here's a list: points, condenser, plugs, wires, battery, and rebuilt the carb. Thinking that one would do the trick but still sputtering. What would any of you think it may be?
Things to know about tractor:
1. Charging is either not working or just barely as battery needs to jump to start but will run all day.
2. Tractor is outside the barn (no room inside).
3. Has GM alt on it. Is under hood but may get some weather if the rain comes in just right.
Other than that the tractor has not been "dressed up" at all. She is in "as is" condition so to speak.
