51 MD Update and hyd pump pic
NEKS
Here is a picture of the M&W hyd. pump. Were there many of these put on back then, were they a higher pressure pump and did they hold up well. Found some water in the rear end and some oil and some bearing parts, so now will have to pull the top off. Did put it in gear and rock it by hand and the motor did move a little(very little).
