Well after looking for the last hour for a gallon of way lube that I know I bought from MSC, I think I accidentally used it in the super a when I changed the engine oil after the big snow. After I changed it, it was put away and I havent run it since.
I know I received the way oil, I found the packing slip along with some other things from MSC but can"t find the oil.
Since I havent run it since, except to drive it to the barn, I"m thinking that it"s most all drained down into the pan and all I need to do is let it all drain out and change the filter.
Wonder if way oil would have any affect on the new front neoprene main seal or anything else in the engine? It"s a much higher viscosity, high pressure lubricant
What a dumb a$$, any thoughts? Think I should change the oil out 2 times to get it all out, run it in between?
scott#2
scott#2
