farmall m remotes
I have a 1947 Farmall M. The remotes are hooked up to a couple of elbows on the right side of the belly pump. There are two more elbows on the left side of the pump. Are these remotes also and will they work the same as the ones on the right side?
these are designed for ih cultivator 1 cylinder on right 1 cylinder on left i cylinder on rear optinal. hydralics will work a one way cylinder or a 2 way cylinder vented on the down side of the cylinder, the belly pump is designed for around 1100# pressure and is a one way system,you should be able to access any elbow that has pressure with with the lever in front of the belt pully pulled toward steering wheel.
As below.
The rear left elbow is a delay port, Ignore it.
The front two elbows are hooked to a "T" inside, so they are pressure up, and return on lower.
If using a two way valve, T into the bottom of the reservoir to make a return
Liftall two Way
Thanks for that diagram Janicholson - Ive been looking everywhere for a diagram on how everything should hook up..
