heat houser for an H
ericy
hello all, I just picked up a heat houser for my H ,on the in side it has printing 1944 Farmall H does any one have one that they could send a pic. of or send mesurements of the mounting hard ware of. The canves is in really good shape and with plow days comming up its gonna be nice to have on the cool days ahead I think i can use 1/2" round stock to make it out of Thank you
The original was 9/16 O.D. Tubing with brackets used to hold it to the axle housing top bolt holes. There were several designs for the brackets for different tractors. Solid rod would work well if held in place with a welded on bracket, biolted to the tractor. Mock up the cloth components for position and clamp to temporary supports, then put the rods in place.
I hope you have some of the metal components. Making them all would be a little difficult. I hope others have the diagrams/photos you need.
Jim
