1256 International tractor hydraulic lines
Jamesb91
New User
I am looking for metal hydraulic lines that go from the hydraulic pump up to the radiator, I"m not sure if these are these high pressure lines or not. Every place Ive checked can not make up the metal lines and the flexible lines are really to thick. CAN ANYONE TELL ME WHERE I CAN ORDER these lines for a 1256 International.
If you have a Colliflower Inc in your area they should be able to make new metal lines. Those are probably cooler lines and I wouldn't think they had high pressure going into the radiator. I would use the braided hoses and reroute them to get them connected to the radiator. Hal
Can you repair your old ones? I have brazed alot of cooler lines over the years. if you have a rotted section you can cut it out with a tubing cutter and put rubber hose in that section. you must use oil cooler hose (oil resistant) and side it on the tube about 4 inches and double clamp it. if you want to stay original a salvage yard should have them. good luck Ed
abcrepairparts
I just thought of something you might be looking for the power steering lines. they run between the frame and the engine and go under the radiator to the steering gear.those lines are high pressure (1500 psi) and have a special end. you can get those lines from CaseIH. they split in the middle inside the frame.
