Front bolster question
Dan W MN
This summer while I was restoring my 48 M, I pressure washed the front half (had to split the tractor for an overhaul). Mice had built a stinky nest up inside the hollow part of the bolster so I shot a bunch of water up in there to clean it out. Now that it has turned cold out I've been thinking: do the hollow legs on the bolster have a drain hole or should I be worried about water being trapped in there to freeze and break?
Thanks for your thoughts on this
I know where you are comin from I found the same thing on my H. As far as the water I'm not real sure if the water can get down there. If youre really worried about it you could probly put it in a heated barn or garage and stuff some rags in it and see if it soaks up any water
