H transmission oil seals
Anonymous-0
I have a 51 H and the two seals on the front of the transmission were the drive shaft yolk and the belly pump shaft go in are both leaking oil. Can anybody tell me how these come out? Do you take them out from the outside or inside of the transmission? Also would anybody happen to know the numbers for these two seals. Thanks
Numbers can be found in the parts section of www.caseih.com. Seals can be pulled out from the outside.
Seals sold by NAPA and CaseIH are made by either Chicago Rawhide (now SKF) or National (aquired by Timken). NAPA and specialty bearing/seal business are usually (not always) cheaper than CaseIH.
