number of zenith carb?
formerly ny bill
where is the model number stamped/engraved on a zenith carb? i need a kit for my 200 but all i can see on the outside of the carb is the "zenith made in usa" cast into the housing.
If the tag/disc is gone from your old one, it would be hard to say what it is. Could be the original, could be a later replacement.
If you're bent on an original, you could start from a parts catalog and search for one. For a rebuild, you could start from an original carb (again, parts catalog) number and find a kit.
For a direct replacement, I know the new Zenith #14007 serves well in the A/B/C series for me. Absent any dimensional issues, you could gie that a try.
If the part # disc is missing, look at the gasket between the fuel bowl and upper body and match it up to the pictures in the rebuild kits. I just ordered an economy rebuild kit for the Zenith carbs. It had the 3 different gaskets in it. I worked great for me.
If the carb is original it should be a zenith model# 67X7. The gasoline #11115 and the kerosene #11340. If it is an aluminum carb the number is probably on a little flat spot on the top of the top half near the front just to the side of the mixture screw.
