manifold interchange
I would like to add yes, but it could be a dual fuel manifold. Probably not out of an M, but you never know. They had a baffle in there to make them run hotter if you moved the lever.
Not a big deal bc it will work either way.
m super m 400 and 450 manifolds will all interchange, but each newer model has a better manifold. the super m manifold has larger exhaust runners and it is not as "hot" as a straight m manifold. so a m manifold on a super m will reduce power a little if that matters to you. ps this description is for gasoline manifolds.
