806 fuel pump
The fuel pump on my 806d is leaking near the priming valve on the pump. It is a slow drip when then engine is off and an steady stream when running. Is there a way to fix this with out having the pump rebuilt? Thanks Brian
Not sure what you mean by "the priming valve". Also we need to know whether you have a RD pump or a RoosaMaster.
It's an RD pump. The IT manuel calls the valve a priming valve. It's a button about the size of a quarter thats spring loaded. You push it up and turn in when bleeding the fuel system.
