Larrydw
New User
I just picked up a set of used 13.6x38 tires on double bevel rims. I was hopping to put these wheels on my super M, which has the same size tires but single bevel rims. I can't get a good measurement of the rim openings on the tractor so I'm not sure if they interchange ok. Do the two rim types both fit on the wheels, or will I need to move the tires to the rims currently on the tractor? Or is there something else that can be done to make them match?
I think we need a picture for this one. The double bevel rims did not start being used until the 400s. The M, SM, SMTA all used a deep drop/dish rim. You tractor could have 400, 450, 460(?) centers on it and then you could use bevel rims.
To be honest I have never heard of a single bevel rim.
Here is a picture of standard M rims of the DEEP DROP TYPE
http://www.hayspear.com/product/CMRIMDEEPDROP/Tractor-Deep-Drop-Rims-Wheels.html?meta=GBASE&metacpg=CMRIMDEEPDROP&utm_source=gbase&utm_medium=CPC&utm_content=&utm_campaign=CMRIMDEEPDROP
Here is a picture of 400 rims of the DOUBLE BEVEL TYPE
http://www.hayspear.com/product/CMRIMDOUBLEBEVEL/Double-Bevel-Tractor-Wheels-Tractor-Rims.html?meta=GBASE&metacpg=CMRIMDOUBLEBEVEL&utm_source=gbase&utm_medium=CPC&utm_content=&utm_campaign=CMRIMDOUBLEBEVEL
(quoted from post at 08:24:07 01/03/11) I just picked up a set of used 13.6x38 tires on double bevel rims. I was hopping to put these wheels on my super M, which has the same size tires but single bevel rims. I can't get a good measurement of the rim openings on the tractor so I'm not sure if they interchange ok. Do the two rim types both fit on the wheels, or will I need to move the tires to the rims currently on the tractor? Or is there something else that can be done to make them match?
You will need a set of the Farmall 400, 450 cast centers before you can use those double bevel rims. The double bevel rims will not interchange with the original drop center rims.
