O-Ring Part numbers for 400
PaddyO
Gents,
Having a hard time crossing some IH part numbers for some seals in my Gas 400. Maybe you can help with crossing them or even a "better idea" for seals in these old tractors. These are in hydraulic system...regulator, control valves, flanges etc....
253 070 R1
350 818 R1
350 684 R1
350 667 R1
Thanks in advance as always.
Happy New Year
Paddy
Those are all old numbers I looked up the new numbers from Case. Only found one cross reference. I think your better off going to Case dealer.
253070R1-86629540
350818R1-9706714
350684R1-75285739 Napa Part# 415
350667R1-86553262
WHY make things so difficult... simply go to the FIAT parts site linked below and look up the current part numbers for the parts you need.
Fiat parts
253 070 R1 = not found
350 818 R1 = not found
350 684 R1 = not found
350 667 R1 = 11/16 x 7/8 x 3/32
My 560-660 parts book is the only place I know where the dimensions are given. My 400 book does not provide that info. Perhaps a later edition of TC-55A does. My book was printed 12-57.
If you get an O-ring kit with 40-50 different O-rings you should be able to get reasonably close, if not right on, with an old original used for comparison. You could also go to a good autoparts or hydraulic store to see if they will match you up by trial and error. Try to find a clerk who is not inclined to "cop an attitude". I no longer do business with a hydraulic shop who once told me they were too busy to find my O-rings while they were outside breaking up pallets next to the dumpster.
253 070 R1 = 7/8 x 1 1/8 x 1/8
350 818 R1 = 1 x 1 1/4 x 1/8
350 684 R1 = 3/4 x 1 x 1/8
Owen....how were you able to come up with dimensions??
Cowman....how did you cross to JD and will that help?
Thanks for all the replies!!
(quoted from post at 02:28:48 01/08/11) Owen....how were you able to come up with dimensions??
I took your four numbers and looked for them in other parts books that had the same numbers along with the sizes. In this case they were in either the 806, 1066 or 2444 parts books.
Very cool....is there an online source you can share or are these
hardcopy manuals you have?
Thanks!
(quoted from post at 22:07:11 01/08/11) Very cool....is there an online source you can share or are these
Thanks!
I have hard copy parts manuals for most of the tractors that I work on.
There are parts listings on line but unfortunately they did not include the indexes from the back of the paper manuals so there is no easy way to find where the part is located on the tractor if you only have the number.
(quoted from post at 07:16:05 01/07/11) 253 070 R1 = 7/8 x 1 1/8 x 1/8
253 070 R1 = 7/8 x 1 1/8 x 1/8 -212
350 818 R1 = 1 x 1 1/4 x 1/8 -214
350 684 R1 = 3/4 x 1 x 1/8 -210
350 667 R1 = 11/16 x 7/8 x 3/32 -115
The (-) dash number to make it EZ'er to locate,,, a buna-N oring should do it...
I keep a Tisco o-ring kit handy # ORD382, it will have the most common orings.
You can go to http://www.marcorubber.com/sizingchart.htm after you measure the o-ring are the grove to locate the dash (-) #,,, your measurements did make it a piece of cake tho :wink: If anyone finds the time to play its nice to know how to figure out o-ring sizing to save you some bucks,,, why pay $5.00 for a 10 cent o-ring :cry:
